I'm usually more technically inclined... but anyway,
I bought a new set of tires, the same day, took a corner a bit too sharp, and smoked the front driver side wheel on a curb at a good clip.
Ever since then, there's been a loud noise coming from that corner (it could be all four -- i might just be hearing the one i'm closest to). It's like a humming noise at all speeds, slow, fast, you name it. Almost unbearable at highway speeds.
The wheel is NOT visibly crooked or cambered... and there is no vibration, and no pull to either side. I'm sure it's out of alignment... but i've owned cars that had a really bad alignment, and none made this much noise.
I remember the car making significant road noise with any tire i've had, but the problem is -- previous tires were either a: worn down completely, b: winter tires.
So could it be a wheel bearing? any way to test? noise does not get louder or change pitch if i rock the car side to side. The tires are Falken ZIEX 512, and are not supposed to be that loud. Several friends have the same tires, and none report the same noise.
Anyway thanks for the help.
