Hey everybody, I started a thread called "growling noise" to see what the responses would be and at the same time I figured I might as well check out old threads and came across this one. The problem here sounds similar to what I'm experiencing with my 2000 ZX3. Tires are Michelin Destiny's with approx. 15,000-20,000mi., both on front are wearing evenly. The noise started 6-8mos. ago, a lite growling noise, kinda like the noise 4x4 tires make. Now its deeper and louder, around 60mph I notice a slight vibration in gas pedal and steering wheel. Replaced right(passengers) side axle after car broke a spring on drivers side and the dealership noted on the paperwork that the center support bearing and left wheel bearing were bad. Talked to tech that worked on my car and he said it was one or the other, after hearing the growling noise when he test drove the car. Checked wheel bearings, could not feel any play, felt smooth when spinning tire. So I went with the center support bearing going bad. Pulled old one out, compared the feel of spinning the old compared to the new. Did not feel smooth, felt kinda dry. I thought cool, this is the culprit. It seemed to quiet down for a while, but the noise is back and now it changes pitch and loudness when I turn wheel to the right. When I turn to the left, it is unchanged from the noise it makes going straight. I have checked the bearings on both sides since the noise returned, still the same. Doesn't seem to be getting any hotter than normal.
Downloader, you said if the noise gets louder on one side, its the wheel bearing. Have you had this same experience and did changing the bearing on the side that makes noise when you steer in that direction solve the problem? Just trying to get some personal experiences and solutions before I waste money(and time) trying to figure this thing out. Thanks, Mike
