1 - 8 of 8 Posts
· Registered
I recently installed a new deck in my focus and I notice on the scosche dash kit that there were no din or anything on how to get it out. I need to get the kit out because I recently got subwoofers and need the plug into the back of the deck. So if someone knows how to get the kit out, please let me know. Thanks
· Jetsetter
which kit do you have? according to their site there are 2
if you have this one, just grab the pocket and pull
if you have this one i do believe that you need to remove the headunits trim ring, and remove the deck with the keys that came with it.
hope this helps
· Jetsetter
yeah there are 2 clips on each side at the lower part of the trim, i have the same kit, it might take a bit of force the get it out the first time, if that doesnt work open your glove box, you can squeeze the sides of the box, and that will allow it to move fully out of the way and you can reach up to the stereo and push the clips from the inside
· Registered
they are all pretty much the same style, couple clips on top and couple on the botton, whenever i wanna take mine out, all i do is pry the top clips down with a really small flat scewdriver and it works good :)
1 - 8 of 8 Posts
