1 - 17 of 17 Posts
Alright guys so, I am now starting my journey to convert my non-SelectShift focus to have the SelectShift option. I haven't seen anyone try this yet so I want to give it a shot. UPDATE: I am in no way responsible for any damages. This is not any easy modification and took me hours of fiddling to get this right. If yoh decide to do this, keep in mind that it is difficult and takes patience. Enjoy. So with the FoCCCus Elm config i changed settings in the IPC and BCM to have the shifter switching to selectshift which made it work! Here is my full writeup: You first need to buy a shifter. Make sure it has a Plus and Minus and three wires. Then You want to make sure the center console is torn apart. There is a thread for that here: http://www.focusfanatics.com/forum/showthread.php?t=259777
next is where the fun starts. You will find the shifter bongle and tap into the wires.
The original shifter had only two wires, a brown and yellow. It connected to the yellow/blue and white/blue wires. But now it will go as follows: brown from the shifter to the brown/violet wire that goes to the BCM which is shift up. Yellow from the shifter to green/white wire that goes to the BCM which is shift down.
And the black from the shifter goes to the black/green wire that goes to the BCM that is ground. I followed this wiring diagram
So now that the wiring is done, you need to use the FoCCCus software to turn the software on in both the BCM and IPC. I first used the FoCCCus software to turn on the Selectshift tech in the shifter type and also in the trans in both the BCM and IPC. You can find that software here: http://www.focusfanatics.com/forum/showthread.php?t=402666 I previously thought that I needed a tune to make selectshift work, but today (May 17th, 2014) I reverted my tune back to stock, with only the Focccus Software changes enabled, and it still worked. So you don't need a custom tune but it makes the shifts soooooooo much faster. I would honestly recommend it.
If you have any questions feel free to PM me and I will keep this as up to date as possible. A special thanks to Tom, at FocusPower for helping me out and the developer of the ELM config FoCCCus software for making this possible! Also, my instagram video: http://instagram.com/p/n8sN9zKiK6/
I was also able to swap in a SelectShift shifter. I wanted to do a quick write up on the install process so anyone else who wants to do this might have an easier time. Sadly, I did not take any pictures, so this is just going to be text (I know, boo). Anyway, here we go.
NOTE: This applies to a 2014 Focus SE HB using a shifter assembly from a 2014 Focus. This will probably work on other years/models, but I can’t verify that. Also, I used FoCCCus 0.8.4. If a newer version is released, the instructions may change.
NOTE 2: I did this a few days ago, so I am going by memory. Please feel free to make corrections where needed and pay attention while taking things apart so you don’t break something. I am not responsible for damages to your car or voided warranties. PROCEED AT YOUR OWN RISK.
Parts and Tools:
  • SelectShift shifter assembly (Should include base, wiring, connectors, shiftknob w/buttons, shiftboot, and shifter plate. Check eBay, I found mine for $100)
  • OBDLink MX (Available on Amazon for about $100. Modified ELM327 will also work, but this is just easier, IMHO)
  • Laptop with Bluetooth adapter (Amazon has USB Bluetooth adapters for about $15)
  • 5.5mm Socket
  • 10mm Socket
  • Ratchets and extensions
  • Stubby Philips screwdriver
  • Flathead screwdriver, long-ish
  • Magnetic Parts Tray (optional, but might help prevent a lost screw. Amazon has them for about $6)
  • Trim Removal Tools (optional, but EXTREMELY handy. Amazon has them for about $5)
  • FoCCCus Software (FREE! Download HERE)
Step-by-Step
  1. Remove floormats and anything in the cupholders and center console. Unplug your phone charger too.
  2. Pull the e-brake handle up as far as possible
  3. Remove the front side panels that run from the underside of the dash to the front of the center console.
    a. Both sides have a large retaining clip that needs to be removed
    b. The passenger side has a small access door that will need to be removed to access the clip.
    c. Once the clips are out, the panels should pull off and slide out
  4. There should be a plastic pocket on the driver’s side of the shifter. Remove by pulling/prying with the trim removal tools.
  5. Remove the e-brake shift boot and trim
    a. The upper most portion of the shift boot can be twisted a little and slide up the e-brake handle
    b. Use the trim removal tools to pry up the front lip of the trim. After the front and sides are unclipped, pull the entire e-brake trim forward and work it off the e-brake handle
  6. Unclip the shifter plate (silver plate with PRNDL)
    a. Using the trim removal tools, pry up on the rear area of the shifter plate, then work the front part up
    b. NOTE: This was the hardest part for me, as I felt like I was going to break it. Everything went smooth, but just be careful.
  7. Remove the shift knob
    a. Put the keys in the ignition and turn to the ‘II’ position. DO NOT START THE CAR.
    b. Put the shifter into the ‘L’ position
    c. Pull the shifter plate and shift boot up past the shift knob
    d. Disconnect the two wire cable for the shifter plate illumination.
    e. There will be two small Philips screws below the shift knob. Remove them.
    f. Disconnect the two wire cable from the shift knob to the shifter assembly. If you have three wires… you probably already have SelectShift. You might want to confirm before proceeding.
    g. The shift knob will pull straight off with the shift boot and shift plate
    h. Press down on the exposed black ‘stick’ and put the shifter back to ‘P’
    i. Turn off the ignition and remove the keys
  8. Remove the forward center console trim
    a. There should be 3 (maybe 4 can’t remember) small screws hidden by the shifter plate
    b. Remove the screws with the 5.5mm socket
    c. This piece should be easy to remove after the screws are out
  9. Remove the center console
    a. Remove the two 10mm screws under the front area of the console
    b. Slide both seats forward and climb in the backseat
    c. Remove the two 10mm screws on the rear sides of the center console
    d. Slide the passenger seat backwards
    e. Disconnect the two cable connectors along the passenger side of the shifter assembly
    f. Gently unclip the cable ends from the shifter assembly
    g. The center console should be removable at this point. Be mindful of the e-brake handle and any other wires that may be connected (potentially different wiring on a higher trim level). Try not to scratch the trim around the front vents.
  10. Remove the shifter assembly
    a. Disconnect the cable on the lower front of the shifter assembly
    b. Gently pull/pry the end of the shifter cable off of the shifter assembly
    c. Locate the shifter cable retaining block (beige plastic square on the front portion of the shifter assembly). It should have a tab facing up and two ‘wings’ on the driver side.
    d. Gently push back on the upper tab with the flathead screwdriver while pulling the retaining block toward the driver side. This part was annoying, fair warning.
    e. Remove the 4 bolts at the shifter assembly base. They should be 10mm.
  11. OPTIONAL: Transfer PRNDS, shift boot, and shift knob to old shifter plate
    a. My new shifter assembly had a dark silver shifter plate, my car has light silver trim and a light silver shifter plate. As such, I had to move things around
    b. The PRNDS/L area can be removed by gently prying up on the rear tab and pulling it down. Be careful, this piece felt brittle to me.
    c. The shift boot is zip tied to the shift knob. I found it was easier to just remove the shift boot from the shifter plate
    d. Using the trim removal tools, pry up on the retaining ring for the shift boot and work the ring off all the way around.
    e. At this point, you can re-arrange your parts as needed.
  12. Re-installation will be the reverse of removal. Please don’t mix up your shifter assemblies or you will have a sad.
  13. Once everything is back together, it would be a good idea to take the car for a test drive and make sure everything works (all gears engage, PRNDS lights up, AUX and USB ports work, power ports work).
    a. NOTE: The ‘+/-‘ buttons will not work at this point, neither will they engage the old Hill Climb feature.
  14. Next up is software, time to break out the laptop.
  15. I did this on a Windows 7 32-bit OS, I don’t think this will be much different for Windows 8/8.1 or 64-bit OSes.
  16. Install the USB Bluetooth adapter and drivers if needed
  17. Download and unzip the FoCCCus software.
    a. NOTE: This software does not require installation, simply run the EXE file when needed
  18. Connect the OBDLink MX to the OBDII port.
    a. Port is located behind a door on the lower driver’s side left. It’s marked OBD.
  19. Sit in the car, the range on the OBDLink MX seems to be pretty short.
  20. The OBDLink MX should light up
  21. Press and hold the ‘Connect’ button on the OBDLink MX for about 2 seconds and release
    a. The blue light should flash quickly, indicating it is in pairing mode
    b. It will stay in pairing mode for about 2 minutes
  22. On the laptop, right click the Bluetooth icon in the system tray and select ‘Add Device’
    a. The OBDLink MX should pop up in the device list
    b. Follow the prompts to complete installation
  23. Once installation is complete, go to Control Panel -> Devices and Printers
  24. Right click on the OBDLink device, go to Properties, and find the COM Port
  25. Turn the ignition to position ‘II’, DO NOT START THE CAR.
  26. Open the FoCCCus.EXE file to start FoCCCus
  27. At the prompt, select the following:
    a. Serial Port: Select COM port for OBDLink MX
    b. Port Speed: 500000
    c. Auto: Unchecked
    d. Maximize Speed: Unchecked
    e. Platform: Not selectable, should default to Ford Focus 3
    f. Language: Probably English
    g. Click ‘Open’
  28. FoCCCus will open the Central Config tab
  29. Click ‘Read from BCM’ and wait
    a. You will probably get and Engine Failure warning on the dash, ignore it
    b. The dropdowns should populate with info
  30. Click ‘Read from IPC’ and wait
    a. The center instrument panel will go blank
    b. The dropdowns should populate with info again
    c. NOTE: I’m not entirely sure which of the above steps is needed, but I used both
  31. Scroll down to the last option in the Central Config tab, ‘#243 Shifter Type’
    a. Change the dropdown to “Select Shift Tech”
  32. Click ‘Write to BCM’ and wait
  33. Click ‘Write to IPC’ and wait
  34. The central instrument panel should now say ‘PRNDS’
  35. Exit FoCCCus (just click the red X)
  36. Turn the ignition off and remove the key
  37. Unplug the OBDLink MX, put the laptop the laptop away.
  38. Turn the car on and go for a test drive
  39. You should be able to put the shifter in ‘S’ and select gears with the ‘+/-‘ now
  40. ENJOY YOUR NEW SHIFTER!
Hopefully this helps someone out!
How To - Paddle Shifters on DCT
Parts Needed:
1. AMG Paddles Part # 1712670046
2. 2 - 10-24 x 1/2" Bolts
3. 2 - external star washers (optional)
4. Voltmeter with continuity tester
5. Various sizes of heat shrink tubing
6. Small spade terminals
7. 3 - T-tap connectors for 18-22 awg wire (Red I believe)
8. 24mm socket for steering wheel bolt
9. Short screwdriver (4"-5" long max.) with a 5-6mm wide blade. I took mine to the grinder to narrow it. *This is to remove the airbag clips*
An invaluable tool for this mod is the Ford Focus workshop manual available on this site.
Steps:
1. Depower airbag as per manual
2. Remove steering column shroud and steering wheel as per manual
3. I made a template by putting paper on the bottom of the paddle shifter and rubbing the edge with a dirty finger to make an out line. I then cut the paper out with a pair of scissors.
4. Lay out template on back of steering wheel and mark with a ball point pen. From the line on the steering wheel edge come in about 1/4”.
[/URL][/IMG]
5. Take a sharp knife and cut rubber covering completely down to the metal frame. On the first side I did I ended up taking the rubber out in tiny chunks, but the second side came out easier by working it up with a scratch awl and it came up pretty much in one or two pieces.
6. Next take a dremel with a good bit (I used a tungsten carbide cutter and it cut like butter). The best method I found was to go around the edge of the rubber and cutting down to the required depth ( I used a digital caliper for this). Once down to the required depth, remove the remaining material in the middle. ( The depth was 5mm, except there are two bumps on the bottom that needed 8mm to clear). This step takes quite a while to cut, then test fit, then cut again. It’s best to sneak up on the fit so you don’t take too much out of the frame.
7. There is a hole in the frame that can be used to bolt up the paddle shifter (it has to be reamed out a little to line up with the hole on the paddle). You will also have to drill another hole to pass the wiring through. The bolts I used were 10-24 x 1/2” and I used an external star washer to keep it from loosening over time. This bolt goes into plastic on the paddle so I carefully cut threads with a tap so I didn’t strip it out. (Don’t over-tighten, there is not a lot of stress here and you don’t want to strip it out or you’re hooped)
[/URL][/IMG]
8. The paddles have a plastic plug on the end that has to be carefully removed without damaging the wires or connectors inside (I used a razor knife and gingerly cut it to pieces)
[/URL][/IMG]
9. Next, run the paddle wires through the hole you drilled and bolt the paddles into position. *Remember not to over tighten them!
10. Re-install steering wheel. Torque for bolt is 35 ft/lbs.
11. Now, on to the wiring. On the black plug in the centre of the wheel, there are three open connector holes. The connectors on the AMG paddles fit nicely into these. The up paddle has a yellow and black wire, the downshift has a blue and black wire. The yellow and blue wires plug in directly, but the black wires have to be spliced together first and then plugged in.
[/URL][/IMG]
12. On the back of the column by the left hand turn signal stalk, there is a grey connector that corresponds to the black connector in the steering wheel. There are three empty spaces in this plug as well. For this, you need to either get some Ford micro female terminals (good luck, I couldn’t find any) or make your own. For this I took an old speaker wire ( which had a large spade terminal and a smaller one, I’m a carpenter by trade so don’t know the proper terminology for all things wiring lol). I took the smaller terminal and carefully cut up the middle of the connector to remove one side. I then put a safety pin inside the connector and closed up the metal with needle nose pliers. This made a small terminal that fit inside the grey plug quite nicely.
[/URL][/IMG]
[/URL][/IMG]
13. From here you need to run your wires to the centre console shifter area. I used a plastic trim removal tool to pry up the cover by the shifter. (Refer to workshop manual for details) Here you will see three wires coming down from the shifter knob. These are for the Selectshift thumb switch. The colors are BROWN for downshift, BLACK for common, and WHITE for upshift (not sure if that is true for all vehicles, a wiring manual for the 2012 Focus listed completely different colors). If your wires are different colors or you just want to make sure, you can unplug the connector, clamp the shifter button in the depressed position (or have someone hold them for you) and use a continuity tester to check the operation of the switches.
[/URL][/IMG]
14. Next, ( I recommend this step as I had some wiring difficulties) do the same on your shifter paddles. With the paddle depressed, use a continuity tester to find out which wire is common, which wire is for the upshift, and which wire is for the downshift. When this is done it is a simple step to use tap connectors to splice your paddle wiring to the Selectshift thumb switch wires.
15. Before reinstalling the airbag, it is a good idea to go for a test drive and check the operation of your new PADDLE SHIFTERS!
[/URL][/IMG]
Old Phart
Made this a "Stickie".
I'm closing it for now, so how-to's on converting models without select shift can be added at the start of the thread later.
Edit: Conversion threads added, kudos to papaacer for the first detailed conversion thread. Reopened for questions/comments/edits.
Old Phart
Here are the links to the complete threads for the two posters of selectshift conversion info..
papaacer::http://www.focusfanatics.com/forum/duratec-ti-vct-performance-2012-current/393898-mk3-selectshift-conversion.html
And parser:http://www.focusfanatics.com/forum/duratec-ti-vct-performance-2012-current/575361-selectshift-conversion-walk-through.html
Thanks to them and bonzo333 for all this info. on converting the DCT control & adding paddle shifters
edit - bonzo333 originally posted here:http://www.focusfanatics.com/forum/duratec-ti-vct-performance-2012-current/569202-paddle-shifters-dct-anyone-have-them-post-26-how.html
Thanks for cleaning it up Roger. Now people can decide if they wanna do the whole shifter base, just the shifter, or paddle shifters.
um, this is nice and all
but
really the pictures are completely unclear on the wiring.
maybe numbering the pins on the connectors and telling which number you plugged each of your wire into would help a ton.
just a suggestion.
Discussion Starter #8
but
just a suggestion.
I also did tell you which wires go to which. I couldn't have made it any clearer than that.
For the paddle shift project, does anyone know what wire terminal (size/type) is needed to properly insert wires into the gray steering column wiring harness? All wires are 22 gauge on this harness. I see here bonzo333 cut up some speaker connectors, but I was hoping to have something more specific that I could order ready-to-go. Thanks.
C
Guest
for any one doing this update, the needed shifter comes from cars with the 201a upgrade package or if buying new it is the one with leather shift handle for a for 2012 to 2014 the number is BV6Z-7210-MC
after taking the old one out and looking at the 10 pin harness plug marked c3245 in the wiring diagram I found all I had to do was plug in new used one i found on ebay,
using a modified elm change the body and cluster shifter "number 243 shifter type to select shift .yes the dash lights up with several warnings and after done I had a fault code of lost cluster communication that needed to be cleared .
Anyone have a tutorial on how to get the airbag out of a 2015 or 2016 steering wheel? I can't for the life of me figure out how to get the clips undone. I've tried twisting, I've tried leveraging in either direction. I have two stubby screwdrivers, one narrower, one wider, and neither are doing jack. Any help appreciated.
I had to twist the screw driver to release the bar and pull out on the bag. It wouldn't pop away from the wheel by itself.
I really want to add just the + gear/ -gear selectshifter to my car, has anyone done this to a 2016 se? dose anyone know exact name of the software I will need to use for the Central ECU Edit on my 2016?
has any1 ever heard of ford dealers or even mechanics doing a selectshift conversion or some kind or similar adding of available options to any vehicle? because I would gladly pay to have the select shift gear selector with the proper corresponding ECU configuration added to my car
thanks in advance.
Does anyone know how to take the shift boot itself off? I'm trying to replace PRNDL with PRNDS. I'm not sure how to take the boot off.
Sent from my Pixel 3a XL using Tapatalk
1 - 17 of 17 Posts
