1 - 8 of 8 Posts
Hi guys, can anyone tell me how to remove the drivers side under dash panel and knee airbag on a 2013 focus? Previous owner installed a cheap alarm and I'd like to remove it. Thanks
I have the panel with a knee airbag in the center and the obd port on the left in a small compartment.
I figured out you have to unbolt the airbag from behind and then the panel is only held in with clips. Pulled on it and it popped out.
There is a side panel on the side of the dash- pry it off and take the torx bit bolt out. Then it just snaps off
My car has the OBDII connector behind that cover.
I install alarms and remote starts on the passenger side behind glovebox. Thats where the bcm is and all your connections so check there before pulling everything apart
1 - 8 of 8 Posts
