If its remotely similar to a non-SVT setup, there should be two bolts that run through the starter and then through the bellhousing and into the block. Its in a pain-in-the-ass spot to get at, just above the differential housing. Once the bolts come out and you unplug the wiring harness the starter should just come straight out.
