My SVT's power steering line blew out of the fitting at the pump, and rather than getting another stock one that is prone to failure I decided to make one out of Teflon Insert SS Braided line and AN fittings.
A very important thing to note is the difference between the SVT and non-SVT Zetecs ... the SVT has the pressure sensor/valve in the hose, whereas the regular Zetec has it in the power steering pump. I have an SVT, and I just eliminated the sensor/valve. That was not the best choice. Without the sensor, I have almost no power steering at idle. Once the engine is above ~1500RPM, it is fine.
The procedure I describe is ideal for a non-SVT. If you have an SVT you need to either come up with a way to retain the sensor, or choose to delete it.
A potential solution for SVT owners is to change the power steering pump for a regular Zetec one. I will most likely try that....if I do, I'll be sure to report back on if it works.
Parts you will need:
M16x1.5 (threads in the PS pump) to -6AN adapter
http://www.summitracing.com/parts/RUS-648060/
90 degree coupler, female -6AN / male -6AN
http://www.summitracing.com/parts/FRA-498103/
two -6 AN Hose End to Female -6 AN
http://www.summitracing.com/parts/RUS-620401/
6 feet of hose is probably too much, but I didn't want to not have enough. Do not cheap out and get the regular braided SS hose...this hose has a nylon insert so it can withstand the PS system pressure
http://www.summitracing.com/parts/RUS-632610/
-6AN to 3/8NPT Steel Adapter
http://www.summitracing.com/parts/FRA-581666/
What you do:
Obviously, remove the stock power steering line.
Install the hose ends to the SS braided line. Take the hose end apart, it breaks down into 3 pieces: the part that goes over the hose, a small fitting that gos inside, and the female AN fitting. Set the female AN part down for now. Take the other end of the fitting and slide it over the hose. Take the smal fitting and put it on the line. It goes between the teflon tube and the braided SS. Then, get the female AN piece again. Put some oil on the neck that comes out of the bottom of it, and slide it into the teflon hose. Bring the other piece up the hose to the bottom of the female AN piece, and tighten it down. Do this for both ends.
I really only needed ~5 feet for the way I routed my hose, but I used all 6 and have some extra in the system. If you want to measure it out and cut the line down, I would honestly recommend it. To cut the line, wrap electrical tape around the hose where you will cut it. Use an angle grinder with a cutting wheel to cut the line. Peel off the tape, and use some snips to clean up any stray/frayed pieces of braided stainless.
Now get your other fittings out.
The M16x1.5 to -6 AN adapter goes into the bottom of the power steering pump. Put a little bit of oil onto the o-ring before you screw it in! I tightened it as tight as I could, and called it good.
Next, get the 45 degree coupler. Screw it onto the adapter you just put into the power steering pump. Make sure you get the end of the fitting to point towards the front of the car when it is tightened down!
For now, we're done with the pump. Time to move onto the line at the rack end.
Now you need to cut the hardline on the stock line where you want to adapt it to an AN fittng. You can either cut it off at the first hardline (before it goes to soft line), or you can cut it off after the soft line. I cut mine after the soft line.
This part requires a drill press and a welder. I do not have either, so I went to a machine shop.
Get your -6AN to 3/8NPT adapter. On the NPT side, the hole is almost big enought to slide the power steering hard line into. Drill out the NPT side of the fitting so the hard line will slide into it (this is where you need the drill press). Weld the fitting to the hard line.
Now you're ready to install it all. Reattach the hard line to the rack, and run the softline out along the framerail.
These [
]*ty pictures show how I routed my line (don't mind the wiring mess you can see, I have some clean up wiring work to do)
This one I tucked up above the foglight after I took the picture
From here, I routed it in front of the lower radiator support then between the support and the radiator and along the frame rail to the fitting welded onto the hardline.
Make sure everything is nice and tight (DON'T USE ANY TEFLON TAPE or any crap like that), fill it up with fluid, and get the air out of the system.
I had the car on jack stands. I filled the reservoir, got in the car, held the gas at WOT (so the injectors don't fire), and cranked it for about 10 seconds whil turning the steering wheel from lock to lock. Check/fill the reservoir, repeat a couple more times. Then I just started the car and let it idle while I turned the wheel back and forth for a while, refilling the reservoir as needed.
I don't really have any other pictures, if you need any just ask and I'll see what I can do [thumb]
I need a new serpentine belt and PS pump, like I said I am going to try a regular Zetec pump and see if it works. I'll report back probably after the weekend.
What you do:
These [
