1 - 12 of 12 Posts
ok so ive been doing some research cus im a do my timing belt and water pump soon everything seems pretty simple exp
ive seen some people say u can hold the cams with a wrench ??? or a special pry bar style tool on the cam pulley its self ? im sure i can build this but my old toyota cams u can hold with a wrench can u do this with the zetec?
yeah u can hold the cam w/ a wrench. the cam itself not the cam gear that is. theres a thread here somewhere w/ a video on how to do a timing belt on the Zetec.
FF's Night Security
I used some big ole' channel lock pliers and clamped down on the cam to hold it. It's best to have someone hold the pliers but I have done it by myself letting the pliers rest against the head, but it left a little dent on the head but nothing that effected it or anything. I did put a rag on the cam to keep from marring it up.
Best move you can make, is to. Replace those torx bolts for the cam gears with ARP cam gear bolts. Trying to hold a torque wrench with a torx fitting , while holding the cams, and getting to the correct torque is a circus act. And remember, snug the cam gear bolts with the cam timing plate in , remove the plate , and hold the cams to torque.
OH, And to loosen those cam , torx bolts the first time. I used a 3/8 impact wrench. A couple short busts worked great.
Discussion Starter #8
oreilly auto parts has this for $35 i am going to use this when i do my timing belt
http://www.oreillyauto.com/site/c/detail/OTC0/6486.oap?pt=N0717
thats great bro but i got that tool from amazing http://www.amazon.com/OTC-6486-Tool...9YA0/ref=sr_1_1?ie=UTF8&qid=1321932347&sr=8-1 for alot cheaper .
but that has nutting to do with breaking the bolts loose or tightening them .. if u try to use that tool while breaking them loose u will break ur cams just an FYI
and an impact is fine for breaking them loose i got one and i dont mind using it but i still rather have a correct way of holding the cam or pulley
this is from an older zetec i think .. but look here how u can hold it with a wrench like normal cams i didnt see this at all on are cams
any info from anyone thats done this job or work with stock zetec cams often ?
Discussion Starter #9
and ARP want 45 BUCKS for 2!!! bolts that's retarded i can get grade 10.9 bolts in this size for a good 2 bucks each ! locally in under 20 mins no shipping or waiting ?
just saying
FF's Night Security
see here
there those lil humps between 2 and 3 but the wrench can and may slip !
You can clearly see the spot to grab the cams with between 1 and 2 not 2 and 4 [thumb]
FYI for those who can't see it, it's the two little squares sticking up.
Discussion Starter #12
those two little squares are for the timing so u know it on compression stroke and i tried craving those too ... theres at a funny ankle the wrench slips ... i just dont see why ford would take the old wrench spot out like they had in the old zetec ....
1 - 12 of 12 Posts
