Since no one has done this I figured that I would.
So you bought projectors from ebay like i did. You wanna know how to wire them up.
End Result.
Heres How.
1.Take all screws off of the headlight.
there are 4 the ebay light will only have 3. Unscrew the 3 that are visible and the one that is under the Headlight.
2. Unhook the wiring harness
3. Hook the harness to New headlight.
The High and Low Beam Are plug and play. Should be self explanatory.
4. Make sure you put the wires running from the amber bulb by the grill turn signal.
THESE WIRES
Now you can delete the grill turn signal
5. Take out the bulb for the turn signal. and unhook the connector running to it.
This is the bulb
This is the connector
6. Cut the three wires a few inches back from the connector
7. Strip the black and green/blue (whatever it is) wire that you just cut off the harness.
8. Connect the wires going to the amber bulb. The black is easy one so you can connect that first. Next connect the Yellow and green/blue (whatever it is) wire together for your turn signal.
You are done and the light should look like this when done
For the Halos check back later! its to cold to do them today
Did one of the HALOS today.
So here is how i hooked them up. they are used as my day time running lights
The wires running from the halos are black and red.
1. The black wire goes to the same black wire that is used for the turn signal.
2. The red wire goes to the orange wire from the harness that you cut.
You are done now! ENJOY. they should look like this when done.
The wires will be shrink wrapped when i get a chance so they dont look like shit like they do. but you get the point
End Result.
Heres How.
THESE WIRES
This is the bulb
