1 - 8 of 8 Posts
Maybe someone has already done this but...
I wanted to do this a while ago but never got around to it. I figured someone here might want to give it a shot. This guy gives a pretty organized "How To" on putting cathodes in footwells while giving you the following options: lights always on, always off, and only on when the car doors open. It's pretty sweet.
http://dtnrox.com/garage/footwells/index.htm
absolutely, or just any power source and install a switch
暗炎
way too complicated, just tap in dome light wire.
Yeah, but electrically speaking, this method is safer. If your hooking up a lot of cathodes you could start blowing fuses if you tap straight into the dome light.
Plus this method alows more functionality. Off, on with door, and always on.
Thanks for sharing!
I ran speaker wire straight to my battery. then for safety i install a fuse.
NO MATTER WHAT make sure there is at least a fuse somewhere on your circuit. its stupid not to
Thanks for sharing!
...and the other thing about that is if your dome fades, it'll kill the cathodes: they can't take the voltage drop as well as LED's.
that poor AP1.... thats probably the first one ive seen with cathodes in it.... sad...
1 - 8 of 8 Posts
