1 - 3 of 3 Posts
So we just replaced the clutch in our 00 Focus. And now the shifting is really sloppy..Anyone know how to adjust it? When you're in 1st gear it looks like you're in 3rd..Thanks!
Posted via FF Mobile
AFAIK, there's no adjustment to the cables. The cables can be replaced, but first you should examine the shift linkage at the transmission, and then at the shifter. I'll bet you find most of your looseness there. I would even guess that the majority of it is in the shifter itself, but I have heard about problems with the shift linkage at the transmission.
Yeah. I found a previous post on here on how to adjust them..Gonna try that and see if that helps. They must have gotten loose when we unhooked the shift cables from the transmission to drop it.
1 - 3 of 3 Posts
