1 - 4 of 4 Posts
hi all.
the problem that i have is that when i start the engine and got warm the rpm drops alot at such point that the engine some times turn off, this doesnt happen all the time(turning off) but the rpm are so low like 600rpm, my car is a zx3 03 ZETEC manual engine.
so i wornder if someone could give me an advise of what could be happening.
or how can i adjust the rpm ?
tnx in advance for any help
i had the same problem..
there is a little screw thing by the throttle cable by the throttle intake, where you can adjust it to make it revv higher..
try it and see if it works for you cause it worked for me..
Shot me 3 deer!!!
to change rpm, you need a tune or a tb w/ an adjustable throttle screw
hi again tnx for the advice i will try it this weeken.. actually i saw the screw in the throttle but before starting to move something i wanted to ask
1 - 4 of 4 Posts
