1 - 6 of 6 Posts
I tried a 1/4" ( 5mm ? ) and that was too thick. I ended up replacing the studs to about 1/2" longer.
I've heard you can run up to 5mm depending on the rim without restudding the car.
You have to count the threads you have when installing the lugs.
I would consider new studs with all spacers, and open lugs if need be.
I tried mine with 5mm and didn't feel safe. I ended up going longer anyway because I went with a 5/8" spacer on the front. Using adapters on the back.
1 - 6 of 6 Posts
