1 - 12 of 12 Posts
hey everyone, how much hp can i push out with all boltons and not going fi? thanks
im going to guess somewhere around 150whp? maybe more, im not sure. unfortunately focus's dont seem to respond aswell to some mods like other cars do.
GreyRice WOoT!
yes fofo almost needs FI to make nice power, avg hp with FI is like 220hp usually 220whp
135 hp with every bolt-on possibly, including chips and tunes but no FI?
That doesn't sound right
That depends what you mean by bolt ons. I know that 165 hp to the wheels is about what you can get if you do most of the mods available (intake, exhaust, header, tune, camps, UDP, ported manifold, TB...what am I forgetting...). Goat Roper had around 200hp at the crank, and that was without FI, but since then he has switched over to a supercharger.
Mtn. Dew
With stock cams, which most do not consider a bolt on, you won't break 135 NA.
With bolt ons you probally wont hit the 150 mark.... 130 sounds like the max for bolt ons.
If you crack the motor open and go higher compression and larger cams, well then we can really say. 200hp all motor is possible but not cheap or easy or reliable.
135whp sounds about right
I kinda consider every engine a bolt-on, except going fi
NA cars are called NA because they have basically maxed the engine out but didn't do it via fi
not to be a prick but arent there like 2 or 3 other threads about the exact same thing floating around?
anyways, yeah prolly about 160 whp is about the max...thats everything w/o fi...including big cams, cam gears, milled and p&p'd head, and good dyno tuning
if u get a ported intake mani then i hear they're good for another few at the wheels
1 - 12 of 12 Posts
