Yeah I would rather see around 500m before changing the filter ... but I will have the car up on a lift while I am in GA for Turkey day, so that's when the change will happen. Still, it will be a good 280 - 300 miles of Seafoam run through.
As for the vacuum line, I was considering doing that just before I leave to drive home. That way I'm belching the black smoke down I-75, instead of mostly in my parents neighborhood. Do you use the liquid seafoam from the traditional can, or the Deep Creep for the vacuum line? I was looking ... and thinking that the deep creep would be a lot easier to introduce, since you could stick the little tube into the line and just spray. Thoughts?
I just read the can of Deep Creep, and its the same ingredients as the normal can, plus CO2 for propellant. So I'm guessing it would be the same benefit and easier introduction.
