Hello
I have a 2004 Ford Focus Mk1 with Duratec 2.3 PZEV engine. A couple of weeks ago the engine check light came on and when I connected it to an ODB2 reader it generated 2 P02004 errors. I googled and found information indicating that I should check for broken, loose, or cracked hoses, as well as damaged wiring that related to MIRC solenoids. I did all that verification and decided to change the MIRC solenoids.
After changing the parts one of the error codes disappeared, but it still shows error p02004 on bank 1.
How can I check the actuator? how do I know it's working properly?
Outside of the vacuum hoses that connect to MIRC solenoids and actuators, are there other hoses or points I should check?
The car works, worse at idle it shakes a lot and sometimes comes to a stop. The odb2 scanner does not report any other error codes.
Can someone give me an idea of how to test the MIRC actuator? Or some other idea of how to correct the error?
Thank you
Thank you
