1 - 9 of 9 Posts
my stock cd player doesnt want to play cds right now. i think theres a cd inside the cd player but i dont know for sure. i wanted to remove the cd -player so i could open it up and check whats the problem but i dont know how to remove the cd-player.
the best thing to do is to use the ford radio removal tools from walmart that are less than $3. you can do it with a coat hanger but it's sort of tricky. if you insist to go the coat hanger way then search for "coat hanger radio" and you'll get what you need.
- Scott
since it is broken have a some fun and see the guts of that thing. break it who cares it is broken.
mine was doin the same but mine was doing it because my memory numbers wernt pushed in all the way
if your car is under warrenty they'll fix it, if it's the 6 cd in-dash changer you might even have luck if it's not warrentied because it's something that is wrong with alot of those radios, tehy get jammed up alot, i wouldn't break it even more, it's most likely fixable, and if it's not sell it, i might even be interested.
- Scott
1 - 9 of 9 Posts
