1 - 4 of 4 Posts
Does anyone know how to get the aux belt back on 1.6 zetec .
is goes round a second pully on the end of the crank to the AC pump but theres no tensioner!
ANY HELP WELCOME
Thanks!
I know nothing about that engine...but if there isnt a tensioner, that means that one of the accessorys has to be on a slot and has to move. Every belt whether it has an auto tensioner or not has to be able to be adjusted..even if it is the old fashion way of moving components manually.
thats what i thought but there isnt one on the AC pump. the only thing i can see are the bolts to take it off but if i did that id dont know if i could get it back on with the belt by hand.
is there some kind of heat shink belt ford uses or something?
Consider buying a Chilton or Haynes repair manual for your vehicle.
It is quite a worthwhile expenditure if you work on your vehicle.
1 - 4 of 4 Posts
