1 - 6 of 6 Posts
so my hood is having troubles latching, it will go down past the first "lock" or click, but it wont go down into the second, where it is secure, no matter how hard i try to put it down, it wont go into the second latch.
has anyone had this problem, and do you know of a way to fix it w/o buying a new latch and cable?
but it has been working fine for a long time, now it has issues, the rubber stops might be to blame?
It's the easiest thing to check anyway. Any time mine wouldn't work, just a couple of turns and it was fine.
but the one that is higher than the other is like super glued in, and if it has been like that for almost a year, what would be the cause of it all the sudden acting strangely?
its possible you may have to either try adjusting he hood stopps, as already mentioned, OR you may have to loosen bolts and adjust part of the latch assembly itself, mechanical things over time get out of alignment my friend.
1 - 6 of 6 Posts
