1 - 11 of 11 Posts
my car slid on some ice and the front driver side hit and the wheel it self was shoved back and rubs the fender now so i had it towed and now its sitting my question is would it be the strut? or the axel will take pics tomorrow
sounds like the control arm if that's what it's called.
Token Engin-nerd
depends on how you hit it
if you hit it head on the control arm should be fine the balljoint usually takes up all the motion. In this case its probly just the strut, strut perch, and inner tie rod. Speaking from experience here lol
If you hit it from the side things are not looking good for you, thats gonna be the control arm, strut, strut perch, inner tie rod, and possibly the axle as well. If you hit it hard enough you can also damage your differential.
ok cool thanks ill snap some pics of it tomorrow
took everything apart its my lower a-arm? it has a huge ass kink in it
Token Engin-nerd
you must have hit it just right then... I'd be really surprised if your strut perch wasnt bent too. It's the piece on top of the strut with the 3 studs in it. Take you strut out and inspect it.
and when you put it back together use a new bolt, go to ford and ask for a strut pinch bolt.
dang man! sorry to hear about your loss...it shouldn't that bad though to replace and get your car rolling again! well atleast rolling with out rubbing
Discussion Starter #8
yeah i looked at the strut and it looks good just cant any place around here with a replacement control arm will any other years fit?
Token Engin-nerd
i told you in your other thread 05-07 are the same
go to car-part.com and search by distance for a junkyard near you
the strut itself may be fine but you need to make sure the three studs on the top are FLAT. if any of the studs are bent down or up, go get a new one, it's $10 at ford.
Discussion Starter #11
yeah i just saw thanks illipino i found one im about to leave to get it
1 - 11 of 11 Posts
