1 - 11 of 11 Posts
What's the highest possible hp exhaust setup that will pass emissions (header, pipes, cat and muffler) Thanks!!!
Torretto!
It will be less if you keep the stock header which has the cat built in for quick light-off, next to that restriction, a 2.5" free flow exhaust system (ie: not chambered) straight through design (ie: fs werks stealth or race) will give you some ponies, really hard to say how many, check the dyno sticky and see if someone has a dyno with intake and exhaust only
w/ my magic bag
A 3'' catted down pipe on a ST...... Do they check for codes or a visual?
Torretto!
3" exhaust may increase overall peak hp but at a lower end loss, and without a header with a 3" collector, or header period, would be a waste, 2.5" would be biggest.
The magnaflow header with cat is supposed to flow better then stock but retain stock size, however the cat is not carb or emissions certified, so you may or may not pass emissions with it, silly as that sounds
FF Affiliate
SVT Focus gained 8-9 HP by adding a 3 inch from header back , SVT isnt 3 inch at collector either
SVT header and 3 inch Exh on a Zetec the least I have seen was 15hp most 19hp and those # are to the wheels
I feel a 3 inch on a decent header on the MK3 will net 5+hp over a 2.5 , I have NOT tested this yet its me guessing and I feel it wont hurt the TQ band anywhere from 2500 on
I’m obx catless with 2.5 exhaust. St res and magnaflow dual exit.
My current power is 196/182 to wheels.
Torretto!
ONLY 196whp? Lmao, don't know what you're doing but keep on doing it. :)
1 - 11 of 11 Posts
