1 - 3 of 3 Posts
Just installed these yesterday on an 04 zx3 with the adaptors. Lights right up but can't switch between low and high beams. Changed the wiring, and now only the highs work. Anyone had this problem?
To save alot of time, this vehicle is not driven on the road.
The signal is sent through the driver side headlight.
Yes, they are bi-xenon headlights.
Thanks in advance.
Flat Black King
Are u connecting them right? Since its the hi/low kit then there should be 3 wires and on the headlights should be 3 female connectors. black is ground so no other wire should be hooked up to it but black. the others would be high and the other is low.
Correct sir, but its still not working. I keep thinking I should use the passenger headlight connector.
1 - 3 of 3 Posts
