I have a 2006 Focus ST just got the car and was aware that it had a high idle problem. I was told it needed a Idle air control valve and did some research and it seemed like that was the problem. I put a new IAC valve in but that didn't do anything. The symptoms are when I'm coming up to stop light/ sign I take it out of gear and am coasting my rpm's go up to almost 3 thow and seconds after I come to a stop they go back down to 1 ish. My high Idle also helps maintain my speed sometimes which I don't want most of the time. I do have a check engine light on, so got it scanned at oreilly's and the first code was fuel was to lean then 2nd code was cylinder #1 misfire. I'm thinking that is a vacuum leak somewhere but not sure if that's my high idle problem. Hopefully yall could shed some light on my problem I'm having
