2000 ZTS Zetec DOHC. Code P0171, STFT up to +30 at idle, LTFT at +20.
I've been over the vacuum system with a fine tooth comb. Vacuum gauge holds a steady 22psi at idle. All hoses and connecters tested, both with ether as well as the old "shove a hose in your ear" test. PCV valve is new, as is the entire hose assembly.
Electrical test of the MAF *seems* ok, voltage moves smoothly with throttle, idle voltage about .7, no crazy jumping around. (I say *seems* cuz I don't actually know what the idle voltage should be.) MAF is clean.
Scan tool shows both O2 sensors doing their roller coaster. (I don't have a high dollar scan setup, all I can see is the voltages and watch them toggle.) One interesting note - the downstream sensor is basically 0v at idle - it only starts to toggle at higher RPMS. (Is this normal?)
Pulling a vacuum on the EGR will kill it, as expected, so not an EGR leak.
TPS resistance scales smoothly from idle to WOT.
As you can see I think I've been pretty thorough, now at a loss for what could cause such a stupidly high STFT.
Next steps anyone? Thanks!
