1 - 10 of 10 Posts
So I purchased a set of projectors from Cosmo Dynamic on ebay. I currently have an HID kit but purchased a new set of H1 bulbs for these projectors. Today while installing everything I found that the HID bulbs will not fit into the back of the projector. Basically you have the bulb and a very thin wire which runs from the tip of the bulb back to the base. This wire is preventing the bulb from fitting into the housing properly. Did they redesign the housings to not accept HID bulbs at all? The H1 bulb that came with the projectors obviously fits in there with no problems. Any suggestions?
coffee, have some
yep, i had to take a pen file and file the hole bigger to get my bulbs in. same issue. beware of metal dust inside. maybe blow it out with air
1 - 10 of 10 Posts
