hi, new here and need some quick help.
Bought 2 dealer only part(s) Wiring Pigtail Kit (4U2Z 14S411 DA) and resistor for the engine cooling fan, since mine fried, and none at the pick n pull or boneyards.
Last person who repaired a/c apparently bypassed the pigtail and ran wires with leads directly into the resistor. (Sorry, not very mechanical here)
The original wires from the harness are 1 solid green and 1 solid green with a white stripe. The pigtail is not coded, only 2 black wires, but the female end cap shows wire 1 and 2, but both are solid black only. (pic attached)
Anyway, since i have no original pigtail and the wires burnt on the end and came off,so they are no longer connected, i have no way of knowing which pigtail wire goes to the harness wire with the stripe and which goes to the harness wire that is solid green.
can anyone tell me or does anyone know if wire 1 or 2 from the pigtail goes to the solid green or white-striped green harness wire?
both the pic attached and the link below may help explain what i am trying to say
Thanks in advance for any help
https://www.youtube.com/watch?v=J3Z7uotk2k4
