What kinda wood working skills do you have?
You run your amp power along the Drivers side, drill a hole about 3" below the fuse box USE A GROMMET!, Seal said hole after you finish running the wire with clear silicone to prevent leaks.
Run your RCA's up the passenger side.
An important question is,
How many watts are you gonna run?
