In a 16" wheel, our pickings are mighty slim. [
] I have found the following adhere to the =>45mm offset rule. Note: There may be other colors or finishes available for the listed wheels.
Kazera KZ-R
16x7 Finish: Silver Painted
Weight: 17.6lbs.
16x7 Offset: +45mm Backspacing: 5.83" Bolt Pattern: 4-108
Rec. Tire Size: 205/50-16
MOTEGI TRACK TRAKLITE
Offset: 45mm Backspacing: 5.70" Bolt Pattern: 4-108
Weight: 12.5lbs.
Rota
Grid Racing
16 x 7
4 x 108
+45
Rota
Slip Stream
16 x 7
4 x 108
+45
Rota
Spider
16 x 6.5
4 x 108
+47 +48
Thats it. I have found others that have like 40 or 42mm offset, but the chances they will rub goes up accordingly. If you find any others please post them. I am looking myself.
Small note: Does not include Ford OEM rims.
