Ok, I am looking to build a very stout NA daily driver. I have a few questions.
1. What is the maximum compression ration on 93 gas.
2. Is there a better block and crank without goin to the aftermarket. SVT or non SVT
3. What is the best STREET head and cam package.
4. Does a .02 overbore add some hp or is it not worth the money.
5. Will the svt block fit with a aftermarket zetec head.
6. What is a good ignition system to run, not a stand alone, Im using the stock computer.
7. Im going to use #24 injectors, will using the SVT fuel pump help.
I will use all forged internals. All will be light weight and will probably use a balanced crank shaft for extra durability. This will be done when I get the money to rebuild the focus. It is a lil sick feelin at the moment.
This is all I can think of at the moment. I would like to get close to 200 at the wheels. I found a place in ohio that will do all of the work, but its a bit expensive. Im trying to build a Focus that does it all and still has great manners on the street, that is the final goal.
