1 - 5 of 5 Posts
I am in serious need of a radio wiring diagram for a 2002 Focus Se!! I've looked everywhere and cannot find one without purchasing it. If anyone could please help me it would be much appreciated.
Typical radio is as such:
Orange/black stripe to constant power (fused) for memory/clock
Yellow/green stripe to power (fused ) during run or accessory
Blue/black stripe to interior lights
Black/orange stripe to anti theft system
Black/green stripe to ground (there are two of these)
White/green stripe to powertrain control module (PCM), with a white/blue tap off of it to the speed control module
white/black toleft front speaker
grey/black to left front speaker
white/green toleft rear speaker
grey/white to left rear speakerwhite/red to right front speaker
radio
white red to right front speaker
grey/red to right front speaker
white solid to right rear speaker
grey solid to right rear speaker.
The first color is the more predominant color of the two when looking at the casings. Hope the is what you needed. Came directly from the Haynes catilog # 36034.
Jim
From a post right above yours amazingly enuff :
Here is the wiring pin out. Dont know if it will help :
Pin --- Color --- Stripe --- Function
Harness 1
1 --- White --- Black --- Left front +
2 --- Gray --- Black --- Left front -
3 --- White --- Purple --- Left rear +
4 --- Gray --- White --- Left rear -
5 --- White --- Red --- Right front +
6 --- Gray --- Red --- Right front -
7 --- White --- (none) --- Right rear +
8 --- Gray --- (none) --- Right rear -
Harness 2
1 --- (not used)
2 --- Black --- Green --- Radio Ground
3 --- (not used)
4 --- Orange (thin) --- Black --- Radio Illumination
5 --- Green --- Yellow --- Radio switch
6 --- Black --- Yellow --- Radio Ground
7 --- Orange (thick) --- Black --- Radio 12V
Harness 3
1 --- White --- Green --- Speed sensor
2 --- (not used)
3 --- (not used)
4 --- (not used)
5 --- (not used)
6 --- (not used)
This is for a standard HU not the Audiophile
1 - 5 of 5 Posts
