This^, that offset looks really really low, you might not be able to get by with a smaller tire, unless you do some serious fender rolling as well before it won't rub.The offset appears to be very low as they seem to somewhat align with the fender lip.
i research the off set and i think this is it Offset is +25mm
That would make your offset worse. It becomes 20mm with a 5mm spacer. As a point of reference, stock offset is 52.5mm and most people try to go with wheels in the 42 to 49 mm area. Less then 45mm and you start to increase your chances of rubbing especially if you're lowered. The lower you go both offset and height) the worse it can get.yeah i tested fitted them today and the brake caliper was touching the inner part of the rim i was thinking running a 5mm spacer or would that be a bad idea
Well crap if you can run thrm, I can run the ones I have then
