1 - 4 of 4 Posts
My focus 2000 zx3 has some problem with the doors. At first the remote control did not work. I changed battery and still can not work. After several days, driver side door was locked. I also tried outside by key and also inside. But still can not open it. Any one can help
Retired Fanatic
Can you open the driver's door from the inside? So basically the door doesn't open from the outside unlocked right? Does the key actually UNLOCK the latch, the thing by the handle or no?
I can't open it inside. The latch is locked. I tried to unlock the latch inside. But failed. Thank you!
Retired Fanatic
Guessing the 'bar' that holds the key mechanism to the lock has come loose. You'll have to remove the inside door panel and see what happenned. Also, is there any 'rattling' in the driver's door now since the door won't open?
1 - 4 of 4 Posts
