1 - 2 of 2 Posts
Hi guys,
New to the forums and looks like i'll be kicking back here for a while.
Just finished FI mods on my 2.0 Duratec HE (ford focus mk2) btw, its an ATX.
Overall tuner did a great job with the build and tune. Boost is at 6psi now, pumping 155whp.
Tranny cooler is in and will be installing a lentech valvebody by next month.
From there will increase boost to produce a targeted 190whp.
After the valvebody upgrade I'm also planning on changing the "stock fuel injectors + 1 injector before the TB" to high flo injectors.
My problem is: I'm having a really really hard time researching what high flow injector will be compatible with my engine. I've been contacting dozens of stores in Europe (btw i'm located in Manila, Philippines) but none can give me reliable information. Most are too big injectors while others give conflicting information.I'm hoping to find 360cc/min injectors.
Can any members with knowledge on a 2.0 Litre Duratec HE help me with this one?
Are the injectors the same as the duratec engines in the U.S.?
Appreciate the help!!
hi im also from the philippines and i've been looking into doing a turbo project on my 2.0l focus. did you have to replace anything transmission wise? or can the stock transmission handle that much torque? suggest you look for places in singapore for the injector parts since they're cheap any they can send you the catalogue of all their parts..they carry ford parts too. even the hard to find bits
1 - 2 of 2 Posts
