I bought a new 2013 Focus hatchback with 2.0L non-turbo engine in April 2013. I let the dealer do the first oil change at 3500 miles. Now at 7500 miles I want to do another myself. (Have moved 100 miles from that dealer.) Looking under the car, I cannot determine where to jack it from using a floor jack. Is there a single lift point that serves that purpose...? Hopefully, there is a suitable lift point at both the front and rear ends of the car.
I also see a fiberboard cover that hides the entire bottom of the engine and transmission. Cannot see an oil pan drain plug, so assume it is hidden behind that cover. Does the whole cover have to be removed to get to the drain plug and oil filter...?
I am really unhappy with the location of the battery in this car -- stuffed up against the firewall. I can remove the front half of the battery cover, but see no way to get the battery out from under the rear half, nor any way to remove that.
Any help here is sincerely appreciated...!
I am quite impressed with the engine in this car, having 12:1 compression, and getting me 44 mpg highway mileage at 50 mph. I'm wondering if any other auto manufacturer is offering a gasoline engine with compression ratio that high. Anybody know...?
Thanks,
Gerry
Thanks,
Gerry
