1 - 7 of 7 Posts
How do I remove the factory headlamp??How many bolt are there holding it??I only found the top three but it seems like there are some more holding it at the bottom. I just want to make sure I remove the correct one.
There is one underneath, on the outer corner, next to the bumper. It's a pain to get to, you have to use either a box-end or open end wrench, cuz a socket won't fit.
Discussion Starter · #5 ·
NOw I got all the bolt. How do I pull the light out. I tried a long time but still no luck. The light is just stack at half way and won't come out. [?|] [?|] [?|]
just keep messing with it. it will come out. there are only 4 bolts holding it in but make sure you unhook the wire plug otherwise it might seem like a harder job than it really is.
1 - 7 of 7 Posts
