1 - 7 of 7 Posts
This is the 2nd time I have to fix this now. I forget what sizes I need, so someone please answer this asap.
I have my oil feed line tapped into the sensor @ the back of my block beside the oil filter. What size pipe do i need. I replaced this once before w/ a brass pipe. Looks like the brass theads broke again. What would you recommend?
I need to get this fix today, so any help would be greatfull.
Discussion Starter · #2 ·
I believe it's a 3/8 pipe. Someone please correct me if im wrong, I'm @ work and can't tear the car apart right now to look.
FF Affiliate
Ravage DONT use break line its way to small inside
If you will use the fitting behind the coil you will find it MUCH easier to get to and it is 1/8 NPT the fitting at the oil filter is a bear and most of the time people damage them trying to get them out
1 - 7 of 7 Posts
