I have a 02 svt a couple of mods. But the ones that could relate to my problems are a stage 2 clutch with a lightweight flywheel.
Okay so here is the problem i cant seem to figure out. There is this noise that sounds like a bad bearing (its kind of like a high pitched humming). Its sounds like its coming from the transmission or where the axles connect to the transmission. When ever the car is in neutral and you rev the engine it does not make the sound but when ever you put the car in first gear and start to drive down the road you can hear it, but not until your hit 5k. When you hit 5k its starts to make that high pitched humming noise. Then when you push the clutch in to shift gears the humming noise goes away as the rpms drop. But as you hit around 5k in second gear the noise comes back. It makes that noise threw every single gear whenever you hit 5k or higher.
Any ideas?
I replaced the clutch, flywheel, and throwout bearing back in February and i dont want to do that again so the car has been sitting for the past month while I'm trying to figure this out. When i replaced the clutch i used royal purple 75-90w transmission fluid. I have already replaced the left axle because i thought maybe the noise could be coming from the passenger side carrier bearing but I was wrong.
Any input would be greatly appreciated. I'm trying to figure this out before I put the car away for the winter.
Thanks,
Alex
Any ideas?
Thanks,
Alex
