I have an 04 SVTF that just starting to have major issues! The car just starts to over heat.... Oil temp gauge pegs out and the coolant temp almost goes to the red. The car on the highway will run normal temp IF you drive it like a grandma and keep the RPM at or below 2800. Gauge says I have good pressure. I've heard a rumor the the oil pressure and oil temp guage is a glorified idiot light.. Is that right? The CEL is on and reading a code for rear o2 sensor... Have had this before and it was just a bad sensor. When all this started to happen I also started to have an oil leak from the back side of the motor. Checked the oil filter to make sure it was tight and only had one gasket... All was well...
Any help with all this would be great...
Thanks, AEllington
Thanks, AEllington
