If you're talking overheating issues relating to no fan function, check the air temp resistor. It's an air temp sensor that tells the fans when to come on. If it's faulty, you won't get proper fan function causing overheating. I believe the part is less than $30 from Ford. It's location is at the bottom of the radiator behind the shroud. I was able to replace mine in about 30 minutes, even though it was my first time. Hope this helps.
