Been there done that
Thanks for the replies, as you guys know this engine suffered for valve seat failure , I went thru one 20,000 miles ago. At that time I basically rebuild the engine as the dropped seat took out a rod & 3 pistons I put new timing belt water pump , had the head fixed with new seats & so on. last week out driving & number 3 cylinder went down , it turned out to be a stuck exhaust valve, I took the head off & wanted to replace the seal behind the pulley that I ask help on how to get off. I have a actual Ford manual on the car & believe it or not all, that book states on that pulley removal is "Remove the crankshaft Pulley" nothing about a puller to use or not but in a later chapter states it has a "Friction fit" which to me is a press fit (I'm also a machinist).
Long story AH! All I have is a new belt so I guess I'll get some rubber or something to try & protect the pulley & pry or break it off. Just trying to fix an oil leak. The damper slips right off but that pulley is on there, had it soaking in Blaster Spray, I just know them skirts on the pulley won't take much prying & they will break off. Sure thanks you guys!
