1 - 6 of 6 Posts
after taking out the altenator, i managed to lose the bolt that holds the back engine eye lift that bolts to the left rear of the block. Does anyone know the thread size and bolt i need to get to get the engine eye lift back on? I need it since i run my ground to it. please help.
Discussion Starter · #2 ·
bump.....anyone?
FoFo Quebec!
Undo another bolt and try it in the hole that's missing the bolt then take it to your hardware store, they should have what it takes to measure the thread.
Discussion Starter · #4 ·
i dont have another bolt like it..... i already tried removing the other engine lift bolt and fitting it, they are different sizes???
FoFo Quebec!
If the bolt only holds the engine lift, you can drive without it. Have a look in a scrapyard and get your bolt there. Probably a metric bolt you've lost...
1 - 6 of 6 Posts
