2001 Ford Focus 2.0 SOHC cranks but won't start. I've got a bright blue spark on each cylinder, 60 lbs of fuel pressure at the rail that bleeds down to around 40 lbs, checked timing belt for breakage/missing teeth/slipped timing, all seems okay. Spray some starter fluid in the intake and I can get a few back fires and pops. Pull the plugs after cranking and don't appear to be wet, so thinking it is a fuel issue. Could it be the camshaft position sensor went bad? Plan on doing a compression test this weekend and getting a node light to see if I am getting signal at the injectors. Any other thoughts??? I'm stumped to say the least...
Thanks!
Thanks!
