1 - 8 of 8 Posts
What would be the main cause for the heater not to blow hot air? It's starting to get cold here and I want to fix this before it really starts to get cold.
Thanks
Low coolant and/or air in the cooling system can do some really strange things too...
There could be a blockage preventing water flow through the heater core. This is easy to check, the heater hoses should both be hot to the touch when the motor is warm. If they are warm, there is coolant flow through the heater core. If you have this and the air output is cold, then the flapper door in the air plenum that is supposed to move when you adjust the hot cold knob is stuck in the cold (bypass air around heater core) position.
1 - 8 of 8 Posts
