Problems with the resistor block would affect speeds 1, 2, and 3. In speed 4, the power goes directly to the fan. If the fan is bad (shorted out) it will blow the fuse in position 4.
Unplug the fan connector and measure the voltage on the plug with the blower switch in position 4. If you are getting full battery voltage at the connector then the blower is most likely bad because you already know that if it is plugged in it blows the fuse.
This is a typical blower wiring diagram for the Focus. Yours may vary slightly.
