There is a door in the HVAC unit which controls how much warm & cold air comes into the cabin.
The actuator for that can quit working properly, so there isn't appropriate temperature control.
On US cars, it's behind the glove box (Right hand side), access on yours MIGHT be above & to the left of the steering column if the parts are the same...
looking for an actuator that moves a lever to control the warm & cold air blend is the most likely issue... since the heater gets warm water all the time & just mixes cold air & warm to control temp..
Luck!
