1 - 5 of 5 Posts
I have an 05 zx3, I purchased an aftermarket seat heating kit for her. What would be a reliable ignition on power wire?
Moved to MkI interior mods for a better fit.
Better chance of finding prev. install info. in this section.
Assuming the factory fuse location is blank, a fresh fused lead from the battery would be my recommendation. Might want to have a relay in the line for control, using key on power to switch it on so it can't be left on accidentally.
Using a volt meter you can find a fuse that is ignition on. If I were near my car I would tell u which I wired my dash cam to.
Anyways once you find it use a add-a-fuse (fuse tap).
Thanks much guys, I would use the radio (yellow) but my wideband is tapped into that. It would be a shame to melt that wire :)
1 - 5 of 5 Posts
