1 - 9 of 9 Posts
· Registered
hi
i already hav 2 twin 12" subs and an amp installed in with my stock 2001 zx3 heaunit..im buying a new headunit cuz i need to ajust the bass because its killing me right now...
my question is do i need to take out my high/low converter? or just wire it up?
thanks
· Flat Black King
the cable that hooks up to the red and white cable from the amp should already be attached to the aftermarket headunit when u buy it. then run the red and white or red and black wires from the headunit to the amp
· Flat Black King
or message me if u need help it dont matter. if u need any other info let me run through it again. The colored wires on the back of your headunit hook up to the aftermarket wiring u buy. then there should be a remote wire that u run a wire to the amp from there. then the rca's go from the headunit to the amp. im pretty sure u know how to hook up the amp to the subs
1 - 9 of 9 Posts
