This has been a problem for as long as I can remember. I don't know if I'm just used to it now or not, but either way, can't really tell if it is getting worse. When my car is idle my headlights and dome will flicker almost in unison with the loud tumble flaps (and engine noise I can't figure out). Again, this has been going on for a long time.
Now I'm sick of it. I want to do what I can to fix it. I've read that it can be a few things:
- bad/corroded grounds
- alternator wiring harness
- corroded battery terminals
Here are my question(s):
- Where are the grounds located in the engine bay that I should check?
- How can I check to see if my alternator wiring harness is bad or not and how to replace? (how-to here has pics that are broken links)
- Anything else that I should check?
My alternator went bad just after year 5 of owning the car (3 yrs ago). So I had it replaced with a new one (and battery too). I'm hoping that it is merely a bad grounding issue that I can clean up myself. I'd hope that the mechanic who installed the alternator would have seen a faulty harness. But that is wishful thinking. From what I've seen, the wiring harness is difficult to get to and do I know exactly what I would need to do to replace it. So any helpful advice is appreciated.
I have a meter to check grounds, so that is not a problem.
Thanks everyone. I can't wait to dish out rep points! [twothumbs]
