1 - 9 of 9 Posts
man oh man. My big problem i have is that my lowbeams only work on one side of my car. i have the ks projector lights with the halos but they worked fine before. The problem i had was that i got a pair of tweezers stuck in one of my headlamp during the install of new bulbs. The bulbs are the right size and they are intact. WHen i switch one my lowbeams the fogs will not work and the lowbeams will only work on the side where the tweezers used to be. Now my brights work hunky dory and fine with the fogs. I think it is a relay or something. Please help
FF #1 Most Wanted
Best thing to do is check all the wiring to both headlights.
Did you splice and swap the wires to correct the normal/bright light switching?
FF #1 Most Wanted
So, when the brights are on, are the inner or outer bulbs on the headlight ?
You might also want to unplug the headlight connector on the rear of the headlight and connect it back on just to make sure you get a good connection.
1 - 9 of 9 Posts
