1 - 5 of 5 Posts
FUBARCUS
2003 ZX3 2016 FoST
What would be the best way to restore my headlight lenses on my lights they are beat up from road debris and other things hitting them. I am planning on putting my OEM lenses on my ebay lights
if your not scared to wet sand
work from a 1000grit>2000grit
after that some polish and laminex to protect it
1. i just did mine the other day and used mother's aluminum polish, and it worked really good. i polished them 3-4 times and they turned out great
2. another way that i found, is to use white toothpaste. just use a rag and rub the toothpaste around on the headlight. you may need to do this 3-4 times to get best results. since it's sorta gritty, it is similar to sanding.
3. and ive heard of lots of people buying a headlight restoration kit at auto zone, which supposedly works well. its just a little more expensive and time consuming that using aluminum polish or toothpast.
I have done the mother's aluminum polish as well, but it does come back and you will have to do it again at least once every week or two
1 - 5 of 5 Posts
